GE iFIX soft license
zjlxcjz1995
Post by zjlxcjz1995 »
The shared soft license is valid for iFIX 6.5 CN, including IGS driver license and Historian 9.0 (100,000 points).
Other language versions have not been tested for availability.
The license is compatible with older software versions, such as 6.0/5.9/5.8/5.5, etc.
iFIX-------------------------------------------------------------------------------------------------------------------------------------------------
License Expiration: Not expired
Number of Terminal Server Connections: 10
Number of Unit Blocks : Unlimited
Number of Process Database Blocks : Unlimited
Number of Drivers Allowed : 8
Number of OPC Connections: 4
Number of Web Server Connections: 5
Number of OPC UA Server Connections: 0
Licensed Version: 6.5
Solution Packs ------------------------------------------------------------------
iPower Solutions Pack : Enabled
Product Options ------------------------------------------------------------------
SCADA with Baseline Database Blocks : Enabled
Statistical Quality Control Database Blocks : Enabled
Batch Database Blocks: Enabled
Control Database Blocks: Enabled
Networking: Enabled
Classic Historian - Historical Trend Reporting : Enabled
ODBC Access to the Process Database: Enabled
Recipes: Enabled Fault Tolerant Computer Support : Enabled
Windows Security Synchronizer : Enabled
Basic Graphics (Character) : Enabled
FIX Graphics: Enabled
NLS Toolkit: Enabled
SCADA Driver Support: Enabled
OPC Connections: Enabled
SQL Database Blocks: Enabled
Workspace (GUI) : Enabled
Terminal Server: Enabled
Dynamics Scheduler: Enabled
Batch Execution VBIS : Enabled
Batch Execution Active Binding: Enabled
Electronic Signatures: Enabled
OPC EDA 2.0 server license: Enabled
FIX Desktop: Enabled
Remote iFIX : Enabled
Extended CDB: Enabled
Fix Entry Level : Enabled
FIX32 Database Builder : Enabled
MMI Databases: Enabled
SCADA Standard: Enabled
FIX Statistics: Enabled
DXF Import: Enabled
SCADA Failover : Enabled
Drivers -------------------------------------------------------------------------------------------------------------------------------------------------
License Expiration: Invalid expiration date
Number of GE PDS 61850 Points : 4500
Number IGS Protocol Families : 54
Number of GE DNP3 Points : Unexpected value
GE Intelligent Platforms Gateway Server (IGS) Core Drivers: Enabled
GE Intelligent Platforms Gateway Server (IGS) 100 Points: Enabled
GE Intelligent Platforms Gateway Server (IGS) iFIX LE Enforcement : Enabled
MTConnect: Enabled
GE Core Drivers: Enabled
(PDS) IEC 61850 Driver: Enabled
(PDS) BACnet Driver : Enabled
Driver5: Enabled
Driver6: Enabled
(IGS) Triconex Ethernet : Enabled
(IGS) Fisher ROC Plus serial : Enabled
(IGS) DNP 3.0 Master Ethernet: Enabled
(IGS) Bristol/IP : Enabled
(IGS) Enron Modbus : Enabled
(IGS) IEC 61850: Enabled
(IGS) Omni Flow Computer : Enabled
(IGS) WITS Level 0 Passive: Enabled
(IGS) IEC 60870-5-101 Master Driver: Enabled
(IGS) Iot Gateway Tier3 : Enabled
Historian -------------------------------------------------------------------------------------------------------------------------------------------------
Number of Connections: 10
Multiple Datastores Count: 150
Rotational Buffer Tag Count: 8800
Rotational Buffer Duration: 678
Number of Points: 100000
Licensed Version: 9.0
Server To Server Distributor : Enabled
Server to Server Collector: Enabled
Calculation Collector: Enabled
Electronic Signatures/Records : Enabled
Allow Data Modification : Enabled
Cluster Support: Enabled
Collector Redundancy : Enabled
PI Collector: Enabled
OPC Alarms: Enabled
OPC HDA Server: Enabled
Expression Support: Enabled
User Defined Tags (Multi-Field) : Enabled
Collector Toolkit : Enabled
Windows PerfMon Collector: Enabled
Microsecond Support: Enabled
Tag Access: Disabled
OPC-UA Server: Disabled
Distributed Historian : Disabled
Model Support: Disabled
Google Drive link:
https://drive.google.com/file/d/13-mLs1 ... drive_link
