[LINK]: TIA Portal v21
TIA Portal v21
https://support.industry.siemens.com/cs/document/109989772
(mirr) https://disk.yandex.ru/d/qA3JuMSnuSSXNA/TIA_Portal/TIA_Portal_v21
Sim_EKB_Install_2025_12_04_password_1
https://disk.yandex.ru/d/wP3kXP5N-wJbAw
https://mega.nz/file/PDoCGCDJ#v3QZvQ7tq8r2_I1Sek6gbaCZs5ChnJVH-MemLupPezM
password= 1
fogwang
Re: [LINK]: TIA Portal v21
Post by fogwang »
Can't open disk.yandex.ru,will you please upload to mega.nz? thanks!
fogwang wrote: Fri Dec 05, 2025 2:41 am Can't open disk.yandex.ru,will you please upload to mega.nz? thanks!
(mirr) https://mega.nz/file/PDoCGCDJ#v3QZvQ7tq8r2_I1Sek6gbaCZs5ChnJVH-MemLupPezM
(mirr) https://www.upload.ee/files/18868409/Si ... 1.zip.html
https://www.upload.ee/files/18868409/Sim_EKB_Install_2025_12_04_password_1.zip.html
saggigo
Post by saggigo »
Thaaaaaaaaaaaaaaaaaaaaank you Cmod (pgood)
jahman
Post by jahman »
Thanks for the update. Time to test V21 :D
giuseppeBG
Post by giuseppeBG »
Many thanks CoMod
Tech Slides https://www.upload.ee/files/18896177/TI ... N.pdf.html
https://www.upload.ee/files/18896177/TIA-Portal-V21-technical-slides-EN.pdf.html
karsan
Post by karsan »
I appreciate and thank you for the great work you are doing but I'm currently facing some issues such as getting two errors while selecting install long keys(attaching the images below) while installing keys. Your help will be appreciated.
Thanks once again.
This error and HelpText from old Microsoft Crypt Library - can conflict with your Windows (version ?) service (boom) (h)
Try in other PC, install FastCopy Key and copy it via USB flash to your PC
S7-1200 G2 v4.1
(mirr) https://disk.yandex.ru/d/qA3JuMSnuSSXNA ... 2_firmware
(dlink) https://mega.nz/folder/qaZjiQYJ#rltIyLgF9dZAHgiL62R-_Q
S7-1200 G2 v4.1
https://disk.yandex.ru/d/qA3JuMSnuSSXNA/TIA_Portal/TIA_Portal_v21/TIA_Portal_v21_2025_11/0_S7-1200_G2_firmware
