KRONES VNC
amirnb
KRONES VNC
Post by amirnb »
Hi all,
On the Krones HMIs with Zenon 8+ which has an inspection units (like Filler, Labeler, or Sleeve Labeler checkmats), the checkmat has its own IP address which can be remotely connected. My guess is that the Zenon HMI is also using VNC to connect to the inspection screen. Do you know what is the VNC password of the Krones inspection/DART system to connect internally?
Thank you
