Dear all
I have micrologix 1400 protected by password and it serial port disabled by programmer,
How can I enable its serial port without being online?
Micrologix 1400 serial port enable
Davizim
Re: Micrologix 1400 serial port enable
If you can send backup project we can try to discover.
omar zedan
Dear Friend
I can not connect to the plc via rs232 cause it is disabled and when I connect to ethernet it ask about password.
If there is a way to enabling rs232 port from keypad of the PLC then I can connect and crack the password using serial port monitoring tool.
Can you solve this issue?
bjyou9999
It is possible.
Look at the PM.
Look at the PM.
