I am looking for WinCC Unified Database Storage V20 installer.
I tried to install SQL server 2022 STD and create WINCCUNIFIED database instance.
Also set the login settings which is mentioned before.
In WinCC Unified PC project I changed the database type to 'Microsoft SQL'.
Unfortantly by downloading the WinCC Unified PC project I get the error that the configured database doesn't match with the runtime database. I had to change some settings in the WinCC runtime configurator, but those are not available.
Has someone the software installed. Is there a registry key or file that is needed?
At the end I want to test a redundant WinCC runtime PC configuration. I the manual is mentioned that for redundancy a MS SQL is required.
