Hey everyone
I converted Beijer program, from E300 HMI to X2 pro 7 - B2 HMI
Firstly
I checked the program in E Designer is "valid"
But, when I converted in ix developer, there are 263 errors
Is it normal?
Sorry I'm newb for this thing
Thanks for every help
						E Designer to ix Developer
				cmos
Re: E Designer to ix Developer
It’s normal. This happens when they use tricky things instead of simple projects. If you follow the conversion guide, you should find instructions on how to manually fix the errors.
You can download the PDF here:
https://www.beijerelectronics.com/en/Pr ... conversion
