hi , i have Delta AS564EST plc and Panasonic minas A6b Ethercat servo . i need to control the servo on Ethercat.
in ISP soft axis setting only delta servos are listed. i added the ESI file for panasonic servo in HWconfig but noting shows regading panasonic servo how to do so?
Delta And Panasonic ETHERCAT
shl235
Re: Delta And Panasonic ETHERCAT
In my experience,
ESI files are not compatible with all PLCs.
You need to create ESI files for Delta PLCs separately.
