Hello I have a Delta DOP-B series with a password locked project inside. How can i unlock the password to upload the project from the HMI to the PC?
I have a password unlocker for the Delta DVP seies PLC but not for the DOP-B HMI. Would you please provide me such tool for the HMI as well?
Thank you!
How to unlock password on Delta DOP-B HMI?
Ivan Bratanov
Guest
Re: How to unlock password on Delta DOP-B HMI?
PLC Password Password Keyword Unlock PasswordSearchMy Profile
No Category
DELTA HMI DOP PASSWORD
EasyTech
February 12, 2025, 10:58 AM
This is the TOUCH SCREEN of the imported machine.
When I try to UPLOAD using DOPSoft, a password window appears.
Disassemble the back of the HMI.
The CHIP inside the square is a NAND Flash EEPROM that contains PASSWORD information.
Let's zoom in.
The entire thing is coated so I can't tell the model name.
If you remove the coating well and mount it with a heat gun, you can see the model name.
Some parts are erased and not visible, but combining the front and back provides complete chip information.
Using a ROM writer, align the PIN direction and install it into the adapter.
Read in the BIN file and analyze it. The CHIP is then placed back on the PCB (soldered).
The capacity is large, so analysis takes a long time.
You can upload by entering the correct password.
Ivan Bratanov
Thanks for the information! The problem is that I'm not familiar with soldering/unsoldering of the chips. Using just a software would be much easier. I have such for the Delta DVP series and it works great. I'm sure that such product exists but I'm unable to find where to download it from.
bjyou9999
This model cannot be decrypted with software.
If you remove the EEPROM and send the BIN file, it can be analyzed.
If you can't solder it, you can leave it to a specialized company.
If you don't have to, just use it.
The choice is up to you.
BlueUnicorn
Hello Ivan! Could you share the programm for unlock DVP with me?
bjyou9999
There is no software.Ivan Bratanov wrote: Fri Aug 01, 2025 4:37 am Thanks for the information! The problem is that I'm not familiar with soldering/unsoldering of the chips. Using just a software would be much easier. I have such for the Delta DVP series and it works great. I'm sure that such product exists but I'm unable to find where to download it from.
It doesn't work with software, so I'm analyzing bin files.
Who doesn't want to decipher comfortably?
Bin file analysis is the best way.
