I'm using TIA PORTAL V14, and I've been following a youtube tutorial about functions and function blocks.
https://www.youtube.com/watch?v=an3sUW6j0vY, @8:50.
And the tutor reached the point to use parameter instance and I tried to use it but it doesn't appear.
Is there a problem with the software I'm using ?
I just installed the main STEP 7 V14 SP1 Professional and S7-PLCSIM V14 SP1.
How to find or use parameter instance feature in TIA PORTAL ?
wolfrose
georg_demmler
Re: How to find or use parameter instance feature in TIA PORTAL ?
it could be that you have not the parameter instances in V14
And never heard about Parameterinstances - we use FBs and Multiinstances - like the third example
Hope this helps
Hope this helps
