I have a library that a software engineer protected with a password.
The library contains a block for a process regulation.
The block is usable but not editable
When I try to open it it asks for a password for a UT user. I don't know the password and the engineer is no longer working with me.
In codesys ide i can export the library ad import it. all work file.
The problem is that access is password protected and therefore you can not modify the code.
Anyone can help me ?
