Good Afternoon.
I have problem last week that all the licences that I had installed by EKB in TIA Portal V15.1, V17, V18 and Step 7 5.5 are all deleted.
Does anyone know how can make the programs work again?
[?]: Licence Block of TIA PORTAL
Re: [?]: Licence Block of TIA PORTAL
EKB self deleted ?
need more info about your Windows X and ALM with screenshots of C:\AX NF ZZ folder
Sim_EKB_2025 not work ?
viewtopic.php?t=218
ALM service disrupted by Windows update KB5058411
https://support.industry.siemens.com/cs/document/109749283
How do you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
https://support.industry.siemens.com/cs/document/24200966
viewtopic.php?t=218
After installing the KB5058411 the message appears:
"The 'Automation License Manager Service' has not been started! Please start the Service."
Remedy
Most of the time, it helps to remove the KB5058411 from the system again and restart Windows or reinstall the ALM as follows:
Uninstall the ALM from the Windows Control Panel.
Open Windows Explorer and navigate to the following path:
C:\ProgramData\Siemens\Automation\Automation License Manager
Delete the Automation License Manager directory.
Delete the almsrv directory at C:\Program Files\Common Files\Siemens\sws\almsrv\
Perform a Windows restart.
Reinstall the ALM Siemens_Automation_License_Manager_V6.2_SP3.exe (301.4 MB) https://disk.yandex.ru/d/qA3JuMSnuSSXNA/ALM
