I would like to transfer parameters from ABB ACS 800 to ABB ACS 880.
The parameters from ACS 800 are taken via Drive window 2.4. as dwp file.
Once when I try to convert the ACS 800 dwp file via Drive composer pro (versions 2.5 & 2.8.1) I got the error
"The software versions is not supported".
Does anybody know what could be an issue?
ABB ACS 800 to ABB ACS 880 parameters transfer
Wendigowood
h4rdw4re
Re: ABB ACS 800 to ABB ACS 880 parameters transfer
Did you follow Drive composer start-up and maintenance PC tool manual?
From page 200 you have explanation how to do that conversion (you have to use Pro version).
An there is note: Not all ACS800/ACS600 drives and software are supported.
Maybe you are out of luck with your software version of ACS800...
