[?] TP900 Comfort bricked?
hojnikb
Post by hojnikb »
I have this Siemens HMI, model number TP900 Comfort.
It appears that firmware must have crashed
It starts at splashscreen for a few minutes, then stays stuck in some sort of prompt.
Already tried USB recovery method, but no luck.
Any other solutions possible?
Thank you! (pgood)
Re: [?] TP900 Comfort bricked?
try Ethernet via ProSave with "Reset to Factory settings"
(sfaq) https://support.industry.siemens.com/cs/document/19701610
TP2200 repair
Start Ok - see Test_Bar
hojnikb
Post by hojnikb »
Already tried that, no luck. Ethernet does not appear to be working. USB otg also doesn't seem to work. (not_allow)
