[?]: add RAM to New_Field_PG IPC MD-57A
roberto_battistella
Post by roberto_battistella »
I bought two 48GB RAM modules for IPC MD-57A but the system does not detect them.
Do you know the correct procedure to set the bios to recognize the new RAM?
Thanks.
(sdoc) https://support.industry.siemens.com/cs/document/109972731
Delivery release of SIMATIC IPC MD-57A (Programming laptop)
Memory 1x 16 GB, 1x 32 GB or 2x32 GB DDR5 SO-DIMM
centipede
Re: [?]: add RAM to New_Field_PG IPC MD-57A
Post by centipede »
only max 2x32GB possible, see Manual
(sdoc) https://support.industry.siemens.com/cs/pd/1706614
Work memory
● Number of slots 2; max. 2x 32 GB
roberto_battistella
il sito dove ho acquistato garantisce fino a 96GB, ho aperto un ticket e vedremo cosa dicono
centipede
Post by centipede »
verrà sicuramente costruita una versione speciale per te
