Dear All
I have 1212 DC/DC/DC 6ES7 212-1AE40-0XB0 FW V3 and I use TIA V15 when I put SD card the PLC work good, When I remove SD card The LED Stop (Solid Yellow) and the LED Main (Blink Yellow).
How can I operate this CPU without SD card?
Actually I borrow the SD card from a friend, Can Any one help me by converting normal SD card to Siemens S7 1200 card??
Thank in advance
[?+]: S7 1200 not work without SD card
Re: [?]: S7 1200 not work without SD card
Power Off.
Insert SMC card
Power On
All work
Power Off
reMove SMC card
Power On
All work ?
https://support.industry.siemens.com/cs ... t/48711409
Download project data into the S7-1200/S7-1500 CPU without TIA Portal
https://support.industry.siemens.com/cs ... /69063974/
How do you detect an inconsistently or incorrectly formatted SIMATIC Memory Card (SMC) and how do you repair it?
Insert SMC card
Power On
All work
Power Off
reMove SMC card
Power On
All work ?
omar zedan
THANK YOU SO MUCH FRIEND
IT IS WORK NOW
IT IS WORK NOW
