Hello everyone
I need to write the value I marked in the Trend Ruler Control to a date/time variable with the help of a button. Is it possible?
https://hizliresim.com/dzflyh8
WinCC RT Prof - How to pass value to variable from Trend Ruler Control ?
SamiCAN42
georg_demmler
Re: WinCC RT Prof - How to pass value to variable from Trend Ruler Control ?
did you read this from Siemens - How do you read out the trend values on the ruler of the WinCC Online Trend Control? - Entry type: FAQ Entry ID: 50353471, Entry date: 10/14/2021
https://support.industry.siemens.com/cs ... w/50353471
Hope this helps
Hope this helps
SamiCAN42
Yes, I read this topic. But it didn't help me much. If you have experience on this topic, can you share a small example? Thank you for your answer.
