Communication between PLC5 to Compactogix
mhi_rockerz
Post by mhi_rockerz »
Hello experts,
I want to estabished communication between PLC5 to Compactogix PLC.
Is that possibe to use Ethernet Interface (AB -1761-NET-ENIW) ?
Or is there have any way to send/receive data between PLC5 to Compactogix PLC?
georg_demmler
Re: Communication between PLC5 to Compactogix
Post by georg_demmler »
I think there a two ways - producer and consumer tags or messages.
About messages you find some information on plctalk.net. For messages you need the hardware for an ethernet-communication.
The AB -1761-NET-ENIW is an Micrologix Ethernet Interface. I think it is not possible to use this part.
Hope this helps.
mhi_rockerz
Hello sir,
Is the produce and consume function ony for Compactlogix and Contrologix Plc?
georg_demmler
you can use the producer / consumer tags for the PLC5 - it works only with the controlNet not with the ethernet.
Hope this helps
