The beginning of the error/alarm event, the red LED flashes on the CP2E-N PLC. The CX-Programmer diagram was created then I transferred it to the PLC along with setting the new IP address, the process went smoothly, after I restarted the PLC indicator, the Run power led was on, Run was also on, err/alm flashing and Ethernet 1 was on.
After the PLC error, it can no longer communicate to the laptop and HMI. Help me please!
How do I reset the CP2E-N PLC so that the err/alm doesn't flash?
PLC Omron CP2E-N ERR/ALM Flashing
hanw2d
