Hi to all
I have problem with servo amplifier Mitsubishi MR-j4-40GF-RJ
I can't to set IP address. In any cases there is 0.0.0.0. And impossible to change and so dosn't pinged from PC or can't finding by PLC FX5U.
SW1-1 - off, SW1-2 - on. So it choices CC Link Field Basic communication.
I try to set SW2 and SW3 in various positions for setting various ip address - but it doesn't affect
The led on LAN port CN1A lights green.
At same time the amplifier without problem connect with PC via usb.
When I try to set in MR Configurator2  in Parameter section the IP address I get a massage "The parameter is write-protected or the data that was written is incorrect"
In  Also there is empty in Diagnostic - System Configuration - IP Address, though the MAC address is indicated
The permision is RW for all group fo parameters (PA19 (Parameter block) = 00AB
I don't understand what could be the reason
