SkyCAD electrical
Тools, Elcad, Eplan, ...
djcatalyst
SkyCAD electrical
Post by djcatalyst »
SkyCAD electrical,
https://skycad.ca/features.php
can someone find a way to crack the software to make it Pro version ? free version is very limited 8)
jandonian
Re: SkyCAD electrical
Post by jandonian »
Installer:
https://my.skycad.ca/sites/default/file ... lv1326.exe
Medicine:
https://drive.google.com/file/d/1uJysK0 ... sp=sharing
Unrar and replace the file in installed folder (C:\Program Files\SkyCAD Electrical).
This is a quick work so I do not know if it works completely. Test and provide feedback. You still have to create a login to run the program, at a later stage I will fix this too.
Enjoy!
Jandonian
djcatalyst
thank you, looking forward for final medicine :)
djcatalyst
Hi Jandonian,
I tested the software, its running perfect with the pro license
I dont need to register, I just replaced the dll and it seems to run smoothly
do you think I can Youse the same dll with the newer version ?
Thanks a lot :)
dustunsoy
Post by dustunsoy »
It was working until new version. As of version 1.3.54, it doesn't work.
jandonian
Post by jandonian »
MEDICINE
This is new medicine for V1.3.61
https://drive.google.com/file/d/1NKj2BX ... sp=sharing
replace the dll file in installed folder.
INSTALLER
https://skycad.ca/sites/default/files/2 ... 1.3.61.exe
Jandonian
