I have PG with Win 3.11 Step7 v1.1
I can't turn on this software, because I haven't authorization.
How activate license ?
[?]: Win 3.11 Step7 v1.1 How activate license
spacedev
https://support.industry.siemens.com/cs/document/114358
MS-DOS handling program AUTHORS V 4.5
Windows handling program AuthorsW V2.5.2
viewtopic.php?f=30&t=218
For NT try Siemens.exe from old keyset
Sim_EKB_2006_11_14a.zip (see Readme inside)
https://mega.nz/file/PCoHSQib#9pYpVBZZE ... Z44FmrxjKA
you can share your version of installation Step7 v1.1 ?
https://mega.nz/file/PCoHSQib#9pYpVBZZEbXvKFhphLRX-YNQsHaXal7HUZ44FmrxjKA
spacedev
Re: [?]: Win 3.11 Step7 v1.1 How activate license
I tried this key:
A1K70010.EKB SIK/SIMATIC STEP 7 Lite V1.0
A1K70020.EKB SIK/SIMATIC STEP 7 Lite V2.0
A1710402.EKB SIK/STEP 7-BASIS V2.x
A1710403.EKB SIK/SIMATIC STEP 7-BASIS V3.x
I see this three license in "Authors" software, but Step 7 no works. Show message that no valid license.
Exist SIK/STEP 7-BASIS V1.x file/license ?
share Step7 v1.1 for testing to mega.nz
place to https://imgbb.com/ screencopy of Autors, C:\AX NF ZZ hidden system folder
remove ALL files from C:\AX NF ZZ hidden system folder
install only 1 key A1710402.EKB SIK/STEP 7-BASIS V2.x
and try again
copy file A1710402.EKB to file A1710401.EKB
install only 1 key A1710401.EKB it will valid for V1.x
and try again
and try again
and try again
spacedev
File: https://drive.google.com/file/d/1At03lU ... sp=sharing
pass: plcforum_u@
I can't delete hidden files.
pass: plcforum_u@
Norton Commander ?
https://support.industry.siemens.com/cs ... t/24200966
How do you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
https://support.industry.siemens.com/cs/document/24200966
spacedev
I tried from Win 3.11
I will wait for information about you test.
Did you install Step7 v1.1 yet ?
spacedev
Is possible create license for Step7 Basic v1.x ?
spacedev
Did you manage to analyze something? Do you think it's more a matter of days or months?
spacedev
