Hello everyone, I'm here to ask for your help so I can change the parameter designations on an omron ns5 hmi. I know that each parameter is in a list within the HMI, I know that what defines each parameter are the move functions right at the beginning of the program. My biggest question is how to make the number of each line in the list correspond correctly on the HMI, as I've tried everything and the parameters don't appear correctly. I am attaching a copy of the PLC and HMI program so that you can check and perhaps explain to me how I can do it.
Thank you very much in advance for your help.
https://drive.google.com/drive/folders/ ... sp=sharing
Help with changing description in hmi omron ns5
rualcosi
rualcosi
Re: Help with changing description in hmi omron ns5
Guy's, i finaly did it. I found the way to do it. Thank's anyway.
