There seems to be an error while compiling the Omron PLC Programme
CX-One, CX programmer, NTST, Syswin ....
Vicky231
Post by Vicky231 »
hi All,
I have successfully uploaded the program via CX Programmer v6.10. All blocks, including function blocks, were uploaded. However, when I compiled the program, I got syntax errors. The program is attached. Can somebody please solve this problem?
https://drive.google.com/drive/folders/ ... drive_link
Regards,
rualcosi
Re: There seems to be an error while compiling the Omron PLC Programme
Post by rualcosi »
Well, 85 errors, you have to try download again the complet program or have to correct this errors by hand. That's my opinion.
Vicky231
Post by Vicky231 »
I tried 02 to 03 times but still got same error.can you please help me how to remove this errors means syntax etc.....
andreyit
Post by andreyit »
In windows, change the fractional part separator from "," to ".".
But this will not solve the problem in FB blocks.
Vicky231
Post by Vicky231 »
One more thing can you please break the password of function block
andreyit
Post by andreyit »
asdf1234
Vicky231
Post by Vicky231 »
Thanks. :)
WaqaSiddiqui
Post by WaqaSiddiqui »
I'm facing a similar issue. Were you successfully able to get your code downloaded without changes?
