PCS7 FREEZES
muntadhersefaa
PCS7 FREEZES
Post by muntadhersefaa »
dear all
i have big problem with PCS7 9.0V SP1 i have install on my WINDOWS 10 PRO all setup are ok . but when start simatic manager run as adminstaration and startup project the program are freeze i can't do anything also can't close it only with end task process .
so please would any one have solve that issue before .
is there any prepare steps most complete on windows before start install PCS7 , is there link for video can clarify each steps end to end that clarify how install PCS7
(h) (h) (h)
PLEASE HELP AND REPLY MY POST PLEASE ...
THANKS ALL
POV_PDA
Re: PCS7 FREEZES
Post by POV_PDA »
The following operating systems are supported in PCS 7 V9.0 incl. SP1 :
● Windows 7 Professional SP1 (64-Bit, only English Windows language version)
● Windows 7 Ultimate / Enterprise SP1 (32-Bit)
● Windows 7 Ultimate / Enterprise SP1 (64-Bit)
● Windows 10 Enterprise 2015 LTSB (64-Bit)
● Windows Server 2012 R2 Standard Edition (64-Bit) (as "Windows Server 2012 R2 Standard
with Update" or incl. KB 2919355 „Windows Server 2012 R2 Update“)
● Windows Server 2016 Standard Edition (64-Bit)
I strongly recommend using only original Microsoft images
muntadhersefaa
Re: PCS7 FREEZES
thanks already know that my friend also try it with win 11 and its work and i try it with windows 10 enterprise and same problem so is there struction must do it before installation can you sent video that clarify the installation step by step
thanks . (oo) (oo)
Re: PCS7 FREEZES
windows is it english version?
run under domain or workgroup?
muntadhersefaa
Re: PCS7 FREEZES
yes dear windows english and used US english language
(no) (no)
it's workgroup
what's should i have to do . can you clarify the steps
thanks . (oo)
muntadhersefaa
Re: PCS7 FREEZES
dear sania
is there specific steps that most be follow and what feature most configure on windows 10 pro before install of PCS7
also which items selected at installation that useful because at installation there are alot of selction product can you sent video or images that clarify specific steps most i follow , because i have suffered from PCS7 manay problems that show up like ( freeze simatic manager or error hierarchy when create new wizard project ..... etc.)
so please please help me (oo) (oo) (oo) (oo)
best wish
regards.
Re: PCS7 FREEZES
for my experience in msmq need mark all of included components, but not check on top of msmq only
have no any idea why it is come for you
MaxS
Re: PCS7 FREEZES
Post by MaxS »
You need Windows 10 Enterprise 2015 LTSB, for example here:
https://office365e3p0-my.sharepoint.co ... 10240&ga=1
Configure Windows 10 before install of PCS7:
muntadhersefaa
Re: PCS7 FREEZES
dear sania
thank you so much for your support and help me with windows features configuration , but can you sent image of selection product at installation of PCS7
please (thnx) (thnx) (thnx)
regrads.
muntadhersefaa
Re: PCS7 FREEZES
hi dear
thank you for your clarify the selection configuration feature of windows , can you sent more image of selection products of PCS7 at installation .
(thnx) (thnx)
MaxS
Re: PCS7 FREEZES
Post by MaxS »
muntadhersefaa wrote: Wed Dec 27, 2023 9:15 pm can you sent more image of selection products of PCS7 at installation
It depends on what you want from PCS7.
One of the examples:
Select Package installation -> Next -> checkboxes PCS 7 Engineering (in the Engineering folder) and OS Single Station (in Runtime/Single Station) ->
Next -> check the S7-PLCSIM checkbox if necessary, accept all the conditions and install.
muntadhersefaa
Re: PCS7 FREEZES
thank you for clarification but need to understand which product at installation should be selected can you sent images that clarified it .
check image below in the link
thanks (thnx) (thnx)
https://ibb.co/NprkwZs
MaxS
Re: PCS7 FREEZES
Post by MaxS »
If you select package installation and check PCS 7 Engineering and OS Single Station all required products will be checked automatically.
You will see this in the next window.
muntadhersefaa
Re: PCS7 FREEZES
dear all
big thanks to all that try assistance to solve my issue , after all can any one sent link of PCS7 which tested ,create project and its work very well by him self and there no problem on it .
please sent the link can be download it
best wish
regards to all (tyou) (tyou)
muntadhersefaa
Re: PCS7 FREEZES
dear sir
thank you for support big thanks but can you sent for PCS7 that already you test it with no problem on it , because this issue make me suffer
thanks again
MaxS
Re: PCS7 FREEZES
Post by MaxS »
Windows 10 Enterprise 2015 LTSB 64-bit (for SIMATIC PCS7 V9.0 SP1, 2, 3)
https://downloadappsforfree.com/downloa ... 2015-ltsb/
SIMATIC PCS7 V9.0 SP1, 2, 3 and more...
viewtopic.php?f=1&t=25324#p99214
p.s. For PCS7 V9.1, V9.1 SP1, V9.1 SP2 - you need Windows 10 Enterprise 2019 LTSC 64-bit
georg_demmler
Re: PCS7 FREEZES
Post by georg_demmler »
this is what I you guess. Make a virtual maschine with Windows10 2019 LTSC (VMWare or VirtualBox).
Make a copy and install PCS7 on this copy. And if something going wrong you make another copy and try again. But first you have to take the correct OS.
If you buy a Siemens IPC the OS will be Windows10 2019 LTSC.
There are lot of videos in YT where you can watch the installation of PCS7 - Search for "Training Installation PCS7 V9 1".
Lots of people guess you to take the correct OS, but it seems you take the wrong on.
