Hallo,
I need to write new software on and older setup. I want to build up the hardware on devices & networks.
The older system has a IM 365 6ES7 365-0BA01-0AA0 that was installed next to the plc and the rack of IO cards.
This IM 365 was connected to a IM 365 R island.
The new setup has a new plc. The older plc is replaced with an ET200. So the new setup has an ET200 and next to it and IM365. Is this allowed?
Second, I managed to have the layout more or less in tia portal. But when clicking on the IM 365 module I don't get any options to configure the system.
I'm not sure what i'm doing is all compatible with each other.
hope someone has a bit of an idea.
best regards,
Wesley
TIA Portal and IM 365S & R
Answers to FAQs
- Faq & Info
Re: TIA Portal and IM 365S & R
im365 is rack extension
you can put in both of racks et200 head
