Unlock NSJ PLC
TNMOR
Unlock NSJ PLC
Hi, Does anyone have a way of removing or finding the password for an NSJ plc in CX-Programmer. I know the NSJ is not as common as other models but I think it is similar or the same to a CJ1G-CPU45H so if anyone has a method for that PLC maybe I could try that? Thanks!
defo2004
Re: Unlock NSJ PLC
Hi! If you have a closed source file with the program, upload it to the cloud and give a link, I think the password can be pulled out of it without any problems.
TNMOR
Re: Unlock NSJ PLC
Great, thanks I will try and get a CF card and see if I can do a backup to it.
conan92
Re: Unlock NSJ PLC
Sir, can you please help me with this program?
I need to unlock FB.
https://drive.google.com/file/d/1A9tlUc ... sp=sharing
thank you sir
thank you sir
TNMOR
Re: Unlock NSJ PLC
Hi I finally have managed to get access to the backup of the NSJ PLC. If you have a chance would you be able to see if it is possible to retrieve the password? Thanks!!!defo2004 wrote: Wed Jul 12, 2023 6:36 am Hi! If you have a closed source file with the program, upload it to the cloud and give a link, I think the password can be pulled out of it without any problems.
https://drive.google.com/drive/folders/ ... sp=sharing
