problem with omron onverter 3g3hv
привода и частотники
omark
Post by omark »
hello evry body
i have a problem with a Omron iverter; it give a error EF3, and i cant Reset this error also i cant enter to progam to make some change it give us only two chose (Fin and Montr)
we cheack the terminals evry thing is good we remove all the controle Cable from S1 to S3 without any result
i need your help about this
rualcosi
Re: problem with omron onverter 3g3hv
Post by rualcosi »
Please check if there isn't nothing insede, like dust and humidity on pin s3, because the manual said that error is a external error on terminal S3, and if you already remove all control cables it may be that the issue.
try to reset the inverter to factory default and see if the problem solved it self.
omark
Post by omark »
thank you for your answer
mybe there is a problem with controle cable but i cheack it with and without cables no result, also in my appilication i dont need terminal 3
for make reset factory i think i must enter to Progm but the driver give me only two chose Fin and Montr
so how i can do reset factory
thanks agian
rualcosi
Post by rualcosi »
Let me check on my job if i can get more information or something that can help and then i'll tell.
