PLC FATEK not running program
hoanganhhao
I uploaded the program PLC FATEK A, then downloaded the program to PLC FATEK B and put it into the machine, it was not able to be controlled. Is there some hidden BIT condition?
mohdabshr
Re: PLC FATEK not running program
Hi my friend
there different in fatek plc if only upload program you may miss data , so the best way is make backup
and this backup will return every things to it position when you make backup.
what you said it happend to me so alawys i make bothe upload and backup.
thanks,
thanks,
mohdabshr
dear
make backup for fatek A, and then Restore it to Fatek B and then A&B will be identical.
thanks,
thanks,
hoanganhhao
Thank you for your response, I am currently doing the upload for the PLC: FBs-32MCT2-AC. And I can't find a backup for it. Can you suggest me software to backup ?mohdabshr wrote: Sun Mar 12, 2023 1:49 pm dear
thanks,
mohdabshr
Hi
it is same winproladder, first go online and then go to tool and choose system backup and after you do your backup and then restore it to plc.
thanks,
thanks,
hoanganhhao
I have done it, 99% success, tomorrow I will check it again. Thank you very muchmohdabshr wrote: Mon Mar 13, 2023 7:59 am Hi
thanks,
