Hello. How to establish a Simotion D - Simatic connection (cpu300), via sfc 65, sfc 66. Data from Simotion D can be transmitted, cpu315 receives.
But I can't get with cpu315, nothing comes to _Xreceive in simotion D.
Simotion
there is a siemens document (but in german) - Simotion Simotion Scout Kommunikation - perhaps you find a solution. We don't know nothing about your Hardware-Konfiguration, Konfiguration of your Simotion.
You can also make a Siemens request to ask for an example or some documentation.
Yes, I have read this manual.
But it is not entirely clear about communication with the GSD.
As far as I understand, it is necessary that the stations are in different projects, the Simotion should be as a slave in the configuration.
But if I install it in the project as a slave, then a configuration error occurs (there is no profibus master).
Do I understand correctly that the GSD must be added to the project of the CPU-315 station?
Do you have any equipment that needs to be repaired? Or do you need to create new hardware, and you decided to insert simotion D there?
I'm asking because it seemed to me that you don't understand what simotion D is.
New hardware. It was necessary to do it in different projects. The problem is solved. I decided to link without blocks _receive, _xsend.
Because for some reason, data from Simotion was transmitted only at the moment of transition from stop to run.
