I have an CX-One project and i want to visualise it in a pc to use it, which program can i use?
Can i use wincc v7.5 to connect to an CX-one project as a scada application? If YES, please give a some advices, like PDF or etc
If NOT, please tell me which application should i use to create a scada from my PLC?
Thanx alot
Can i use Wincc 7.5 to connect to an OMRON PLC?
rezarahnama1360
skross m p
Re: Can i use Wincc 7.5 to connect to an OMRON PLC?
Hi! There is such a thing called the Internet, if in this thing through a search thing, for example google or yandex and other similar things, enter your question everything will clear up. Enter "wincc plc omron" in the search bar, then these things will give out the addresses of several hundred sites with answers to your question... There is such a thing called OPC Server, open any search engine and you will find it... Here is the very first link that opened with the help of an Internet search https://forums.mrplc.com/index.php?/top ... c-omron-cj / please see the rest for yourself...rezarahnama1360 wrote: Thu Dec 22, 2022 3:28 pm Hi,
Thanx alot
rezarahnama1360
Hi
Believe it or not i searched alot but the more i searched, the more i confused.
By the way thanx aot
skross m p
rezarahnama1360 wrote: Fri Dec 23, 2022 1:12 pm Hi
I wish you success...
rezarahnama1360
