Indusoft project password protection unlock
tkfei
Hi. Anyone can help to unlock the Indusoft password protected project file ?
Thank you.
Thank you.
HooK
Re: Indusoft project password protection unlock
Yes. Your password is: a9plus2k18
Enjoy!
-HooK
Enjoy!
-HooK
Asokkary
HooK
@Asokkary I can crack the Script Engine password protected section of the Project file. I can't crack the password to unlock the whole project... I don't think that is possible. If anyone was successful please let me know.
jandonian
Can you tell us how you are cracking the script password? If you share your knowledge, may be someone will take it for there and find a solution for other passwords?
Jandonian
Jandonian
HooK
I know you (jandonian) have shared lots of your cracked app with us in the past, so I thank you, and because you are generous, I'll share briefly:
Run the project and attach process to x32dbg, you will see IndScriptEdit.dll & mfc110u.dll loaded, set breakpoint on PostMessageW on both of those modules, and enter fake password... Now look at the stack window in x32dbg and you see the fake password and real password being compared.
This is easy and doable because it's using the unencrypted IndScriptEdit.dll for this. The main project password for users is encrypted and it not being managed by IndScriptEdit.dll.
Cheers,
-HooK
Cheers,
-HooK
Toms
Asokkary wrote: Thu Jan 19, 2023 1:44 pm
Please for this project also
https://www.mediafire.com/file/6ce8devg ... w.rar/file
HooK
Toms, are you able to find the password for InduSoft project file? or did you remove/reset it from the project file?
We can't see what you did...
tkfei
Thanks a lot for the help
Toms
Hi, Hook, the password has been specially processed. I can't retrieve the original password and can only change itHooK wrote: Wed Jan 25, 2023 4:09 pm Toms, are you able to find the password for InduSoft project file? or did you remove/reset it from the project file?
HooK
Not true Toms. Not sure if it's the language barrier or not, but you didn't change the password. You simply deleted tagl.bin from the Database folder which resets the Security Group for the project.Toms wrote: Thu Jan 26, 2023 1:00 am Hi, Hook, the password has been specially processed. I can't retrieve the original password and can only change it
That method doesn't always work...
I thought you were able to find a way to (more cleverly) reset the project password...
Asokkary
Can you change the password or clear it?Toms wrote: Thu Jan 26, 2023 1:00 amHi, Hook, the password has been specially processed. I can't retrieve the original password and can only change itHooK wrote: Wed Jan 25, 2023 4:09 pm Toms, are you able to find the password for InduSoft project file? or did you remove/reset it from the project file?
Toms
YESAsokkary wrote: Thu Mar 02, 2023 11:07 amCan you change the password or clear it?Toms wrote: Thu Jan 26, 2023 1:00 amHi, Hook, the password has been specially processed. I can't retrieve the original password and can only change itHooK wrote: Wed Jan 25, 2023 4:09 pm Toms, are you able to find the password for InduSoft project file? or did you remove/reset it from the project file?
Asokkary
Ok can you do it for me in this project?Toms wrote: Thu Mar 02, 2023 1:33 pmYESAsokkary wrote: Thu Mar 02, 2023 11:07 amCan you change the password or clear it?Toms wrote: Thu Jan 26, 2023 1:00 amHi, Hook, the password has been specially processed. I can't retrieve the original password and can only change itHooK wrote: Wed Jan 25, 2023 4:09 pm Toms, are you able to find the password for InduSoft project file? or did you remove/reset it from the project file?
It's asked me for user name and password to modify the project
I need it
Codex_Xt
Did you got unlock your file
I to have same problem
Indusoft web studio 7.1 sp3
File has user login, the operator has forgot the password.
Anyone know how to remove for reset the password
Plz help it's urgent
ransh
Dear Friend,
Please help me and unprotect a project developed in Indusoft web studio.
Thanks a lot!
Thanks a lot!
dipesh1410
ransh wrote: Fri Jul 12, 2024 1:33 pm Dear Friend,
Thanks a lot!
https://www.mediafire.com/file/obivw31x ... 4.rar/file
Ahmed95
HI
ogui
Can someone help me unlock a project in Indusoft 7.1? I need to do an HMI retrofit.
