Hi, My name is Amrit and need urgent help. I am new to step 7 V5.2 and wincc 5.1.
I got a job with faulty computer motherboard. Hard drives working fine with USB converter.
Now i prepare same environment in second computer.
Please let me know how to transfer safely program from Hard drives to running computer.
If I copy same folders and past in same location, then it will work or not.
Project file is around 27GB.
please guide me.
[?]: how to transfer step 7 V5.2 and wincc 5.1 project to other PC
amrit
Re: [?]: how to transfer step 7 V5.2 and wincc 5.1 project to other PC
Hello. A lot depends on the configuration of the computer on which Step 7 and Wincc were running. The best thing is to find a motherboard exactly like the one that failed. In any other case, you will need to re-configure the work of Step 7 and Wincc.
amrit
thank you for your reply. I prepared second desktop computer with same environment. but wincc v5.1 and protool 6.0 sp2 license keys unable to find. now step 7 v5.2 except program and responding well but wincc shown me in demo mode.
I try to boot program with windows startup , it boot 100 percent but give error. please guide me. May be due to wincc v5.1 not licensed and also tags number is 3400.
use old Siemens.exe utility for install keys for wincc v5.1amrit wrote: Tue Nov 29, 2022 5:03 pm thank you for your reply. I prepared second desktop computer with same environment. but wincc v5.1 and protool 6.0 sp2 license keys unable to find. now step 7 v5.2 except program and responding well but wincc shown me in demo mode.
viewtopic.php?f=30&t=218
For NT try Siemens.exe from old keyset
Sim_EKB_2006_11_14a.zip
https://mega.nz/file/PCoHSQib#9pYpVBZZE ... Z44FmrxjKA
orCode: Select all
https://mega.nz/file/PCoHSQib#9pYpVBZZEbXvKFhphLRX-YNQsHaXal7HUZ44FmrxjKA
https://disk.yandex.ru/d/FFQrIWcMWe5gqQ
you can made image file by WinImage
amrit
Sir,
I tried but it show " Only short Keys for wincc v5.*/4.*".
So what to do?
Please reply.
So what to do?
Please reply.
install Short keys from WinCC/WinCC 5/WinCC Interface folders via Seimens.exeamrit wrote: Tue Nov 29, 2022 10:00 pm Sir,
So what to do?
Please reply.
install
A9WRT430.ekb SIK/SIMATIC WINCC RT 64K PowerTags
or A9WRT460 from WinCC 6 folder
see About keys for WinCC viewtopic.php?f=4&t=11415
