EDS file develooment
Nicocorp
Post by Nicocorp »
Does anyone ever wrote an EDS file from scratch? I'm in need to write one in other to have a custom made device to talk to a Guardlogix.
Please let me know if is there any software required or guidelines.
Thank you.
h4rdw4re
Re: EDS file develooment
Post by h4rdw4re »
If that device is not custom made then it is, a lot, easier to ask manufacturer or download from their page EDS file.
Basically it is ordinary text file which can be modified, if you know what you want to achieve and how that device should/could communicate with logix controller.
There is tools from some manufacturer which can generate EDS file, like ABB Drive composer (https://library.abb.com/d/3AXD50000012770)
I tried it once and got EDS file which is not working as it should.
Probably I expected to much with not to much knowledge :D
Some help follows.
Logix 5000 Controllers EDS AOP Guidelines for Logix Designer
https://literature.rockwellautomation.c ... _-en-d.pdf
Regards.
Nicocorp
Post by Nicocorp »
Thank you very much, Its a custom made device, I know It's gonna be a challenge but there is not working around if I insist of my DYI solution, but maybe is a good opportunity to learn making mistakes.
Thank you so much.
