Hello friends.
I went and downloaded from a CJ2M CPU33, I have these files. Can somebody tell me how to open them in CX programmer so I can change a setting in an input or delete- add another input.
https://www.4shared.com/account/home.jsp#dir=oLLQWY3l
Thank you.
Help with CJ2M backup.
Toms
Re: Help with CJ2M backup.
Hi friendsotos wrote: Fri Oct 28, 2022 10:09 am Hello friends.
Thank you.
Please send me an email and I will send you the recovered program
defo2004
Thank you.
Hi! It's very simple, open CX-Programmer, select the "File" tab, select "upload comment\program" in it, in the "download from file" window that opens, specify the path to the file. In your case, you need to specify the path to the backup file that you
have , the CJ2M- CPU 33 file , the Programma.obj file
After downloading it, you will have your program....
This program has a password-protected task and several FB blocks....If you need access to them, write me a personal message about it, I will answer you.
sotos
Thank you my friend.Toms wrote: Sun Oct 30, 2022 1:18 amHi friendsotos wrote: Fri Oct 28, 2022 10:09 am Hello friends.
Thank you.
sotos
Thanks a lot for your time.defo2004 wrote: Tue Nov 01, 2022 11:02 amsotos wrote: Fri Oct 28, 2022 10:09 am Hello friends.
Thank you.
