Hello, I need to reconfigure my Nams-11 control board to a 55 kW power unit, for this there is a service menu
 when i connect with acs601 running drive it show all parameters. I can also access group112 and 190. For changing old card ratting or reconfigration. I did not found 112.6 parameter for HW change. it show only 112.1 to 112.5. my question is?
1- how to access p112.6?
2- when i connect new card namc-11. it show [empty memory]-{0}-{254}.it did not show any parameter.
please help me for NAMC-03 and NAMC-11 configration.
						abb acs600 namc-11programming
				Ramomkosta
Re: abb acs600 namc-11programming
Hello, man, I think you need UPLOAD a firmware of your old NANC-03 AND RESTORE to NANC-11 using RUSB-02, with DriveWindow Softtware.
That's the first step, after that, you need set the Inverter type.
				Tripe
Hello, at the moment my namc-03 board is faulty and there is no way to unload parameters from it, but I have working namc-11 boards.Ramomkosta wrote: Tue Oct 18, 2022 9:06 pm Hello, man, I think you need UPLOAD a firmware of your old NANC-03 AND RESTORE to NANC-11 using RUSB-02, with DriveWindow Softtware.
Could you describe the complete procedure on how to change the type of invert on the namc-11 board?
I will be very grateful for your help
				Ramomkosta
Please, send me your e-mail.
