Request: Lauer Tool for Touchpanel 1200TC
Nedjeljko
Post by Nedjeljko »
Hi I need to read a project made in Lauer tool - The Panel Project I need to read out and make same on Simatic Panel is WOP-iT GX1200tc 05502-X7.
I've found couple of installations but those installations have no 1200tc panel inside.
Can someone help me and upload the proper Version of Installation for Lauer HMI...or at least to tell me which SW Version I should look up arround.
Thank you in advance
andreyit
Re: Request: Lauer PCSPRO for Touchpanel 1200TC
Post by andreyit »
You need WOP-iT.
Nedjeljko
Post by Nedjeljko »
Thank you very much for your fast answer - I will try it and let know for others if it work for my Project with 1200TC panel Project. (tyou)
andreyit
Post by andreyit »
For the latest version, you need to download the four parts of WOPiT_222045. Then install WOPDEMO_222045. Then install ServicePack_SPL1_222045. For the license, copy the file WOPiT_222045\_Crack\woplic.dfn into the program folder.
And pray that it was possible to upload because the program looks like CODESYS, where you can not upload if the programmer has not downloaded the source code.
Nedjeljko
Post by Nedjeljko »
I did as you explained and everything is OK. I've successfully open the Projects and now I can do what need to be done.
Thank you very much for your Support - Links and explanations. (clap)
Cheers (pgood)
