SICK CLV630 Barcode Reader (TCP/IP) to Siemens S7-1200
kambiz
Post by kambiz »
desr all
i need help for :
SICK CLV630 Barcode Reader (TCP/IP) to Siemens S7-1200 ????
Re: SICK CLV630 Barcode Reader (TCP/IP) to Siemens S7-1200
usually is not problem, try to read :https://support.industry.siemens.com/cs ... /109747710
typically you are use tcp_server in plc and barcodereader is client
into block out have the ndr parameter mean "new data record" one shot bool within up you are store the record parameter into separate memory and use in program
