Hi everybody,
I need help from all of you. I had a machine which using ACSM1 with firmware UMFI1030, when I tried to use Drivestudio, it will pop up a message window "Texts are not available in the active language for the drive connected to {1}{247}". It can read all the parameters but cannot backup. It will pop up "Backup creation failed. Failed to load backup file names, Error -Unknown error 0x80004005". The computer OS using is windows XP with Drivestudio 1.5. I had tried to upgrade to Drivestudio 1.6 and Windows 7 with different computer but all had the same problem.
I had success in drives with with firmware UMFI1460, 1480 and 1510, but not ok in UMPI1030.
Do anybody have any idea on this problem
						ABB ACSM1 UMFI1030 cannot be backup by Drivestudio
				kenlam
