Hi
I have plc s7 1200 how i can know the version of tia portal used for upload the program directly without needing to install all the version of tia portal and try one by one
Tia portal used for upload any programs
MEFinc
Re: Tia portal used for upload any programs
If your PLC is not too old (I don't remember exactly but FW need to be V3.0 or higher and TIA Portal V13 or higher) then you can watch version of TIA Portal project in: Online access => Your PLC => Online & diagnostics => Diagnostics => General => Version of TIA Portal project.
Mustablanco
Thanks a lot
