Unity V11.1 how to edit DTM externally
другие контроллеры
Imanu
Post by Imanu »
This is the case, I have a TSX programmed using unity V11.1
It scans I/O slave by modbus TCP (wago 750)
I need to add a slot with 4 analog inputs but, then I need to increase the ammount of words to read from the slave by 4. All the existing digital inputs, 264 variables, have to be offset by 8 bytes. The editor inside unity is very poor. It is not possible to drag all variables down or modify the offset. The only choice in the program is to delete and create the variables again in the correct offset.
Anyone know a way to externally edit the DTM file? it does not seem to be possible to export in this version of unity.
