https://support.industry.siemens.com/cs ... /109806651
It is sad that it did not provide download, someone do try to get it via support request but they did not give him as it is not related.
It seems to be very good, please share if you could get it via link up.
Thank you!
The LHermes library provides a standardized horizontal communication within a SMT-line (Surface Mounting Technology) based on specification IPC-HERMES-9852. The library is programmed according to Siemens programming style guide and “PLC open” guideline.
Within a SMT-line the Hermes protocol coordinates the PCB board handling. The LHermes library provides Upstream and Downstream Client functionalities according the Hermes Specification V1.4. Optional features like Board Forecast, Board Query and supervisory channel for remote configuration allows an even more efficient production.
