Good evening,
I have a problem with PLc schneider Pro-Face LT3201,it does not start,I dont know which software is used to communicate with it,also i dont know if i can copy the program installed in this PLC and download it in the PLC schneider Pro-face LT4201 ,can you please help me.
				SE_support
Re: schneider Pro-Face LT3201
Hello, it looks you have to use GP-Pro Ex Software for LT3201:
https://www.pro-face.com/files/pdf/prod ... nual_e.pdf
If it doesn't start there is no way do save the application from HMI.
But may be it's only back light issue? What is the status of LEd on the front?
Best regards
Best regards
