S5 FROM AWL TO KOP
mocho
S5 FROM AWL TO KOP
Post by mocho »
hello
It is possible traslate this to KOP ? Thank you.
        UN	T 0
	U	E 33.5
	S	M 10.1
	U	M 10.1
	=	A 32.0
	UN	E 33.1
	S	M 10.2
	U	M 10.2
	=	A 32.1
	U	M 1.2
	O	M 100.0
	R	M 10.2
	R	M 10.1
	UN	M 10.1
	UN	M 10.2
	UN	M 20.0
	UN	M 20.1
	=	A 32.6
	U	M 20.1
	=	A 33.4
	U	M 20.0
	=	A 32.2
	U	E 33.2
	O	E 33.4
	O	E 32.7
	O	M 100.0
	=	A 32.7
	U	E 32.7
	O	E 33.4
	O	E 33.2
	UN	M 10.0
	=	M 1.2
	U	E 32.7
	O	E 33.4
	O	E 33.2
	=	M 10.0
	BE
Answers to FAQs
Faq & Info
Faq & Info
Re: S5 FROM AWL TO KOP
Post by Answers to FAQs »
like this
// net1
       UN	T 0
	U	E 33.5
	S	M 10.1
// net2
	U	M 10.1
	=	A 32.0
// net3
	UN	E 33.1
	S	M 10.2
// net4
	U	M 10.2
	=	A 32.1
// net5
	U	M 1.2
	O	M 100.0
	R	M 10.2
	R	M 10.1
// net6
	UN	M 10.1
	UN	M 10.2
	UN	M 20.0
	UN	M 20.1
	=	A 32.6
// net7
	U	M 20.1
	=	A 33.4
// net8
	U	M 20.0
	=	A 32.2
// net9
	U	E 33.2
	O	E 33.4
	O	E 32.7
	O	M 100.0
	=	A 32.7
// net10
	U	E 32.7
	O	E 33.4
	O	E 33.2
	UN	M 10.0
	=	M 1.2
// net11
	U	E 32.7
	O	E 33.4
	O	E 33.2
	=	M 10.0
// net12
	BE
write all section into separate network & change view awl->kor
gtvpic
Post by gtvpic »
In STEP5 it is not possible in LAD to have more than one coil in the same segment, in the sent code there is more than one coil in the same segment, therefore it is not possible to represent it in LAD
The solution is to copy the code of each of the Coils in a separate segment and place the "NOP 0 " instructions necessary for the STEP5 to perform the conversion from STL to LAD.
Seeing how simple the code is, it is preferable to translate it directly in the STEP5 proprio to KOP instead of copying and revising
