Dear All
Can I call FB (TON) inside FC?
If I do that the TON has its DB it is created one time, How does that happen if I used the FC several times?
[?]: TIA V16 - FB (TON) inside FC?
xflash
Re: TIA V16 FB inside FC
I have been troubled for this for a long time, use inout for TON or others.
With every method, you will need to use DB or Merkers So use FB will be better.
omar zedan
Re: [?]: TIA V16 - FB (TON) inside FC?
Thanks So much
