Dear All,
I need the RS232 Diagnostic port pinout of Euchner ASi Gateway GMOX2. It is a 6 pin Mini Din Female port.
Thanks in advance
Chandhaa
Euchner GMOX ASi Gateway RS232 connector pinout
Re: Euchner GMOX ASi Gateway RS232 connector pinout
are your sure with 6 pin - I found something with 9 pin
PIN Designation of the D-SUB connector
Pin 3 Data line B („RxD/TxD-P“)
Pin 5 DGND (0 V)
Pin 6 VP / +5 V
Pin 8 Data line A („RxD/TxD-N
The AS-i/PROFIBUS gateway sends and receives signals on pins 3 and 8 of the
D-SUB connector. The PROFIBUS signal “RxD/TxD-N (data line A) 1 ” is located
on pin 8, the signal “RxD/TxD-P (data line B)1 ” is located on pin 3.
Pin 5 (0 V) and pin 6 (5 V) supply 5 V DC for the bus termination resistor.
Pin 5 DGND (0 V)
Pin 6 VP / +5 V
my last post was wrong - it is the profibus connector - I will look for the Diagnostics interface tomorrow
