Help STL temporary local data simatic manager
Mustablanco
Post by Mustablanco »
I have a program used stl and fbd programing ,when i want to know the datablock number, i find temp98
Problem is how i can know the datablock number used
exemple:
      SET
      L     #IN0
      T     #TEMP98     //  <------?
      OPN DB [#TEMP98]
      A     M      0.3
      JC    M014
      L     0
      T     DBD  396
      T     DBD  376
      T     DBD  368
      T     DBD  364
      T     DBW  388
      T     DBD  520
      T     DBD  524
      T     DBB   43
      T     DBB  533
      SET
      R     DBX  400.1
      R     DBX  402.1
      M014: NOP   0
georg_demmler
Re: Help STL temporary local data simatic manager
Post by georg_demmler »
don't know to understand your question - but you can take sfc 24 "Test_DB". This sfc check if the db is in the program / CPU or not.
Hope this helps
Mustablanco
      L     #IN0
      T     #TEMP98               //  temp98 is temporary local data,but how i can find the value of temp98 in DB Data block
      OPN   DB [#TEMP98]     //  here  DB temp98      is DB1 OR DB 132 OR DB 25 How i can find the data block number
But in my program there is no SFC 24
gigi10
Post by gigi10 »
L #IN0 probably some input to your block, which contain block number to open
T #TEMP98 temp98 store to local memory
OPN DB [#TEMP98] opend DB in input #IN0
gigi10
georg_demmler
The DB-number comes from #INO
Because L #INO
T #TEMP98
You have to look at the interface of the fb - what is #INO - Input, Output, IN_OUT, STAT, TEMP?
IF #INO is an Input / IN_OUT than it is definied in your main-program. If it is definied as STAT or TEMP than you have to find a place like L... T #INO.
But without your program I can only guess.
Mustablanco
verify your private message i send you the program
georg_demmler
thank you very much.
The code-lines in your first post is in the FC70. And #INO is an input parameter.
The FC70 will called in FB120 - Network 10. And here you can see, that INO has the value of 122 - you open in FC70 the DB 122.
You can find out with Refernce list.
But without any symbolic list it is very hard to understand the program.
Hope this helps.
thanks
Mustablanco
Thanks brother
I'm working for the comments and symbols to make the program easy understand
Hello
I have this program ,the problem is when i want to find temp47.temp55 block FB134 network 30 i cant find the value ON and OFF come from
If anybody can help me please
Link of program:
https://www.mediafire.com/file/kyaqcy30 ... 8.rar/file
Answers to FAQs
Faq & Info
Faq & Info
Post by Answers to FAQs »
network 3
with in row 2 load db 132 & :
      LAR1  P##TEMP47
      L     DBW  378
      T     LW [AR1,P#0.0]
mean: L DB 132.DBW378
T #TEMP47
bit by bit
TEMP55 is 0.7 of TEMP47
#TEMP47.TEMP55 = db132.dbx378.7
TEMP47 looks like status word
georg_demmler
L DBW 378 -- is a bad style
better you write
L DB 132.DBW378
Mustablanco
I try it to activate the value of db132.dbx 378.7 but the data block don't take it
I want to force it the value to prove the correct address
Answers to FAQs
Faq & Info
Faq & Info
it coming from fc74 called in fb130 net 2
fc 74/5
      A     #TEMP37.TEMP38.TEMP49
      O     #TEMP37.TEMP38.TEMP44
      O     #TEMP37.TEMP38.TEMP47
      =     #TEMP3.TEMP11
you are need to search temp37.temp38
it come from net 3
      CALL  "DPRD_DAT"
       LADDR  :=#TEMP118
       RET_VAL:=#TEMP119
       RECORD :=#TEMP37
it is status word of some field device with logic address 280
temp11 is your bit
Mustablanco
Hi
My problem is resolve thanks for everyone may help me
