Siemens cpu as Crypto miner
lalocbzxy
Is there a way to use a plc/cpu like simotion as a miner? Run any kind of algorithm
Rex2701
Re: Siemens cpu as Crypto miner
God damn you!!! ))))
All the coolest cryptocurrency miners around the world work for a plc/cpu like simotion!
cuongletan
Interesting question — theoretically, PLCs like Siemens Simotion CPUs aren’t designed for crypto mining. Their architecture focuses on real-time control, not high-volume parallel computation like GPUs or ASICs. Even if you could run a mining algorithm, the hash rate would be extremely low compared to dedicated hardware.
However, if your goal is to analyze, monitor, or recover wallets rather than mine, you might want to look into AI-powered recovery tools.
For example, the AI crypto wallet finder and wallet finder software can scan local and industrial systems for lost wallet data, seed phrases, and key remnants — all done safely and legally.
Developers who experiment with IoT or embedded devices sometimes integrate these tools to detect crypto traces in unusual systems. You can explore the open-source components on wallet finder crypto or learn more from community resources like wallet finder.ai.
Wow! We're awake. Don't get the joke ? Ye?
