Empty Login Page - WinCC Unified
socrames
Post by socrames »
Hi all,
I've created the following project (see attachment) to start expermenting with WinCC Unified.
- In WinCC Unified Configuration : I've created the web server with all default settings
- In TIA Portal: I've started the simulation of the project
- In Simatic Runtime Manager: the project appears as running
When I launch https://localhost in my web browser, I get the welcome page of WinCC Unified server.
Then when I click on "WinCC Unified RT", I get an empty page.
Does someone have an idea what is going on here ?
The project file (v17) is here if needed : https://we.tl/t-7p7rUMShDA
Thanks in advance
Re: Empty Login Page - WinCC Unified
socrames
Post by socrames »
Спасибо my friend. This video is a good resource for using the PLC web server as visualization through "View of Things"
However, what I'm trying to established is a standalone WinCC Unified web server on a PC system.
That PC-based HMI will communicate with multiple PLC.
For now, what I've got is the web server running, but with an empty page when I browse https://localhost/webRH
hello,
are you mark check box " visible on web" ?
are you choose startup screen for web user?
socrames
Post by socrames »
Strangely enough, the problem is now vanished.
I've just restarted my virtual machine (where the WinCC Unified is seated) and reloaded the WinCC Unified project, and just like that now it's working.
Thanks guys for your support
