S7-300 SET TIME OF CPU
kouim92kostas
Post by kouim92kostas »
Hello...
I would like your help for settting the time for S7-300 CPU....
The set time instruction is :
CALL "SET_CLK"
PDT : =
RET_VAL:=
Lets say that I send the time from the HMI to PLC to DB10.DBW64. How i transfer it to SET_CLK? What i have to write to PDT and RET_VAL?
I have already variable of the data type DATE_AND_TIME, in which the time is stored (using the READ_CLK).
I read the manual but stil I can't understand the way it must be done! (If you want I can send screenshots if it helps)
I don't know anything about these instructions so I'm a bit confused!!
And somethimg else. In S7-200 the TODR and TODW are not working parallel... The same goes for the S7-300 too?
Thanks a lot....
Answers to FAQs
Faq & Info
Faq & Info
Re: S7-300 SET TIME OF CPU
Post by Answers to FAQs »
(sfaq) https://support.industry.siemens.com/cs ... t/26961516
How do you do the summer/winter time switchover with WinCC flexible (update to version V1.1)?
Use the "Set PLC Time" button to transfer the specified time to the PLC
kouim92kostas
Good morning.... Thanks for your reply...
But I'm not sure this is what i want to do...
The question remains.... How i transfer the time i send... To set_clk... And the parameters of this function what I write to them.?
Answers to FAQs
Faq & Info
Faq & Info
I use this FAQ in real PLC S7-300.
Press screen button and set new time of PLC
