[?+]: Step 7 CPU 317F-2 PN/DP - Safety Password
racartapo
Hello All,
I really need help to solve an issue that is happening in a Siemens Step 7 PLC CPU 317F-2 PN/DP with a Micro Card Memory 2MB.
This was running well, then went to stop mode and many leds were flashing (SF, BF and Stop). I checked the Program and this was gone, no more program.
I downloaded the program again using the Hardware Configuration password (9991) and all program went properly but when I trying to put this in Run, this goes to Stop mode and shows problems at the PLC Buffer.
PLC Buffer said:
- STOP caused by STOP command, FB number: 1639, Module address: 3084, Previous operating mode: RUN, Requested operating mode: STOP (internal).
- Safety program: internal CPU error, Internal error information: 7:0000, Instance DB no. of the causing F system block: 837, Previous mode: RUN
Requested mode: STOP.
I reset PLC, load again the Program, I replaced the PLC for a new one and nothing works. I didn't replace the Memory Card but I don't know what else what to do.
I tried to open the FC1630 F_CALL to see something and maybe compile but I don't have the Safety Password and I can do nothing.
I really need help to see if anybody can see the Program and tell me the Safety Password and also if anybody can check the Buffer PLC and see if any possible solution or reason why I am having this issues in this machine. Machine is down and pressure is crazy.
Any help will be great appreciate.
Here is the Program and Buffer PLC
https://www.mediafire.com/folder/htnz4j ... wrt/shared
ppp
Re: [?+]: Step 7 CPU 317F-2 PN/DP - Safety Password
safety pass: 30D608
roberto_battistella
Hello. which tool did you use? for block privacy protection how can it be done? thanks a lot. Hello.
racartapo
PPP thanks a lot for your help, I really appreciate that.
Did you have any chance to look the PLC Buffer? just to see what you think could be the problem?
Thanks again !!!!
Thanks again !!!!
xflash
Wow, welcome back ppp
Please consider updating pss7 for wincc picture password and safety password for Step 5.X.
Welcome back and stay safe!
Gilles Kamgno
hello every one, please i have the same problem, can you help me to get the password of this program
https://drive.google.com/file/d/1z5rTdE ... sp=sharing
Mustablanco
Hello sir i unlocked all the blocks for you, you can downloads it from this link
https://www.mediafire.com/file/69hpoixv ... 2.rar/file
roberto_battistella
the safety blocks are still password protected
Mustablanco
I will send you an image to prove,all the blocks are unlocked
Can you send me your email address
Mustablanco
You mean the password of the program ,not the protection of the blocks
your password is :123
try it and let me know if work for you
roberto_battistella
Ho trovato anche io questa password
Mustablanco
Its work for you or no????
Buitrungdo
i HAVE A SAME PROPBLEM WITH S7 400.
Mustablanco
What kind of problem you have , i can help you
thanks
thanks
beckdsign
Can you help to find safety password
I sent you in pm
Thanks.
I sent you in pm
Serg70
pss7_v1.84a.exe working
craw941
How did you manage to get the password? can you tell us?
ISHAK
i have the same problem does anyone know how to solve it
https://www.mediafire.com/folder/6y46y4 ... 14-06-2024
Info
- Faq & Info
pack your project to zip and post a link
Tomek
Can You remove or check the safety password from the file https://drive.google.com/file/d/12EV6V8 ... sp=sharing
Anybody??
Anybody??
GGGG
Dear Magicians,
Could You please help with the attached Step7 project?
The safety password is successfully lost... the engineer who made it enjoys his retirement since a decade or so.
Maybe there is a PLC password maybe not I don't know.
https://limewire.com/d/AAFOW#5C7u5is209
Thanks in advance.
GGGG
Thanks in advance.
GGGG
